Niko__srb
Sep 20, 2023Follower
Orbi rbr10 satelites
Hi guys, little question , is it possible to connect another orbi satellite to a orbi rbr10 router ? Because i need another satelite and i can't buy just the satellite for this version.
Sep 20, 2023Guru - Experienced User
Maybe however not sure if just any RBS will work:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Other options you can try are RBS20 or a RBS40v. Non Orbi options would work are EX series extenders, EX7500 or EX7700.
