ricotto
Feb 22, 2022Tutor
Orbi RBR10 slow LAN port speed
I can only get about 200 Mbs download from my rbr10. When I connect directly to the RBR10 LAN port, speedtest shows : Download: 179.6 Mbps Upload: 17.8 Mbps When I log into the admin portal ...
Mar 02, 2022Guru - Experienced User
also, make sure to have qos, access control, traffic monitoring, and parental controls all disabled.
If they were ever enabled, you might need a factory reset of the router.
the RBR10 was the most base model mesh system and wasn't that powerful.Gigabit speeds takes a pretty good cpu if you're going to be doing any packet inspection and those services put a strain on the cpu and can slow speeds. Sometimes even disabling them doesn't take the load of the cpu and a reset is needed.
ricotto
Mar 02, 2022Tutor
Ah, I do have the traffic meter and security enabled. I'll check. I can disable the traffic meter. Not sure about network protection.
