ricotto
Feb 22, 2022Tutor
Orbi RBR10 slow LAN port speed
I can only get about 200 Mbs download from my rbr10. When I connect directly to the RBR10 LAN port, speedtest shows : Download: 179.6 Mbps Upload: 17.8 Mbps When I log into the admin portal ...
Mar 03, 2022Guru - Experienced User
What are you thinking of putting in bridge mode?
Different manufacturer's use the term "bridge mode" to mean different things.
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
ricotto
Mar 03, 2022Tutor
Ok, so turns out that the LAN interface on the RBR10 was acting wonky. I would plug in the laptop, do a speedtest and find that it was sometimes slow, sometimes not. It was very helpful to look at advanced>show statistic in the web admin interface. Watching that with another laptop show that it would "flop" between 1000M/Full and 100M/Full. I set the interface to on the laptop from Auto Negotiation to 1000M/Full Duplex and got the higher throughput.
I factory reset the RBR10 and re-installed the latest firmware and now I am getting 943.52Mb/s through the RBR10 LAN port consistently.
Thanks for everyone's help.
Kudo's to plemans.
