Valley54
Apr 17, 2020Aspirant
Orbi RBR10
Hi all having massive problems with Orbi RBR10 router and 2 x sattelites and been going through Netgear support for well over 6 weeks now with no progression! Basically what I am trying to do is ge...
Valley54
So, the goal is to set up OpenVPN to enable reaching your LAN from the internet, correct?
Yes that is correct.
I have yet to subscribe to a VPN host (Nord, Polar, express etc.) until I can get the Orbi sytem to connect to it via the OpenVPN client that is installed into the Orbi system, if that makes sense. Therefore getting the Home Lan system (Ring cameras,PC's, Security cameras etc) protected when connecting to the internet to send me feeds and when external from the home other equipment connecting into the Lan safely all via the VPN service.
From what I understand the VPN service can have up to 6 connections at any one time
Therefore if I have the Works PC's (I work from home and have 3)
The Ring security system (cams, alarm etc.)
My Lads Xbox
My PS
The wifes phones etc
All connected at once (ISP tells me I have up to 20+ items connected to the lan/internet at any one time) then thats the 6 simultaneous connections and more!
However to get the home LAN onto the VPN Service Provider via ONE connection using the Orbi and OpenVPN then this would free up "slots" or connections to the VPN Service Provider for items (Laptops phones etc) ouside of the home environs to also be connected via the VPN Service Provider to the home LAN and therefore a better level of protection is afforded.
Hope this makes more sense
CrimpOn
Apr 17, 2020Guru - Experienced User
Valley54 wrote:So, the goal is to set up OpenVPN to enable reaching your LAN from the internet, correct?
I am sorry that my explanation was not clear. The Orbi OpenVPN software is a HOST, not a client. It is for devices in the internet to connect TO devices that are on the LAN behind the Orbi. Counting the number of devices inside the Orbi LAN which want to connect OUT has no meaning. It appears what you want is a VPN client that enables devices inside your LAN to reach the internet. Orbi does not do that.
- Valley54Apr 17, 2020Aspirant
I'm not sure if I'm explaining myself properly so you will have to forgive me if I seem to not understand this very well...
Basically I want to connect the Orbi via the OpenVPN client to the VPN Service provider As best described using the simple diag from NordVPN where the Squared blue logo is the Orbi router and connection on the right hand diagram "Router with NordVPN" on the attached diagram (Hope that works as it wouldnt allow me to insert the deiagram intop the main post)
The only issue is many VPN Providers do not allow or support direct connections via certain routers (Orbi being one) UNLESS they can tilise a client such as OpenVPN to allow access.
This was one of the reasons I obtained the Orbi as its one of the few Mesh router systems that have Open VPN provision and therefore allow this to happen.
Hope that makes a bit more sense
- CrimpOnApr 17, 2020Guru - Experienced User
Yes, what you are saying makes sense, except for that you were misled about the capability of Orbi's OpenVPN client. It is a VPN Host, NOT a client. I know this sucks, but it is correct. Just saying, "supports OpenVPN" is correct in terms of OpenVPN Host. It is incorrect in terms of OpenVPN client.
Send it back.
Hmmm ok not disputing what you are saying but that flys against everything that Netgear Tech have been saying all along. They stated on numerous occassions that OpenVPN should work with a VPN Service and the Orbi...the main issue they have is that they cannot get the OpenVPN to work with the Orbi!!
If what I understand you are saying is true then what is the point of OpenVPN being on the Orbi setup at all? Along with the no.ip account you are required to sign up for?
Also if the Orbi cannot be used with a VPN Service using the OpenVPN via the router then they are being lets say economical with the truth , with not only their sales but also their claims on what the unit can do...and therefore is selling all the Orbi equipment with OpenVPN unfit for purpose!
