ferio23
Jan 02, 2023Follower
Orbi RBR10
So, I consider myself to be a rather tech savy person. Over the years, I've played around with home Wifi mesh systems and I feel that the Netgear Orbo RBR10 model I have has been the most consistent ...
michaelkenward
Jan 03, 2023Guru - Experienced User
ferio23 wrote:
Second, is there a difference to connected to the Orbi in the Orbi app "locally" or using the "Anywhere access." It looks like all settings in the Orbi app are "read only" as you can't make changes and have to connect via the web login.
Not much difference. They give you access to the same features.
I don't know which settings you see as "read only" but apps are designed for simplicity and cannot manage every setting on a router. That's why the browser graphical user interface (GUI) is there.
