vivekb
Dec 28, 2023Aspirant
Orbi RBR20 - buffering even at high speed
I have an RBR20 with 2 satellites that are about 2+ years old and has been performing very well in my 3500 sq ft house. Earlier this year, I switched my internet provider from Cox to TMobile. Even af...
Dec 29, 2023Guru - Experienced User
Have you checked with the ISP and ISP services to see if there are recent issues there?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
vivekb
Jan 02, 2024Aspirant
Thanks a lot FURRYe38. I did reset all the devices in order and restarted them. That did not resolve the problem.
This issue takes place only the devices are connected to the Orbi wireless network. It does not happen with wired connection. There are no issues even with the wifi sys-id of the T-Mobile (ISP) router. Only with the Orbi wireless sys-id.
I am sorry I am not very technical. What is RBS, and how do I turn it off? Also, how do I check the channel configurations?
The firmware version is: v2.7.4.24.
I will let you know the details of the ISP modem.
