GN100
May 18, 2020Follower
ORBI RBR20 - download speed
Using the Netgear ORBI app on my iOS device it shows speedtest figures of approx 500Mbps down and up (I'm on a gigabit internet plan) ...... but running spped test by Ookla ..... shows no more than 7...
May 19, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
