myshko
Oct 04, 2019Aspirant
Orbi RBR20 - Intel AX200 Wifi Losing Connection
Hi, Having an issue with Orbi RBR20 router with two sattelites. New laptop with Intel AX200 wifi. Upon connecting to the orbi network, there initially is internet for about 30 seconds, then y...
- Oct 13, 2019
Just to follow up, Have sinced used a couple of different router models, one wifi 6 router, and another AC mesh system. Both worked fine. So it looks like there is some sort of issue with the Orbi routers and these early wifi 6 cards from intel. Could be a device / driver issue, but as the cards work with everythinng else tested its more like the Orbi. For now it's been simpler to just replace the Orbi.
schumaku
Oct 13, 2019Guru - Experienced User
myshko wrote:So it looks like there is some sort of issue with the Orbi routers and these early wifi 6 cards from intel. Could be a device / driver issue, ...
Common issue under some cominations, depends on the radio chipset (makers) of the routers. Head to the Inhell driver update section and grab the current drivers - vendor distributed drivers are typically outdated, or released very late. Known issue with both the Inhell AX200 and the Killer (which is again a very similar Inhell chiset).
myshko
Oct 13, 2019Aspirant
Cheers,
Yes have tried both vendor drivers direct from Dell Pro support (newer than the ones on the support page) and the latest intel drivers. Plus the latest killer drivers. No change. But yes the Intel AX200 and killer AX1650 are essentially the same intel chipset.
Thing is, the issue isn't there with other routers (netgear, Asus, Linksys, TP-Link) have connected to so many without issue, including another mesh system.
Plus, if you turn off the satellites, it connects to just the Orbi router fine. So it looks more likely to be some handover between the router and the satellites. Would file a bug report / feedback to netgear but they don't have that type of support.
