tgermain
Dec 09, 2021Aspirant
Orbi RBR20 - no upload speed
Hello ! So my problem is about upload speed (download speed is as expected). I should have about ~20 mbps according to my ISP, but I only have something arround 0.01 (yes really !). I have a ...
- Dec 13, 2021
I found the solution.
On my internet setup page, I configured PPPOE with my login/passw coming from my ISP. I just change "Does your Internet connection require a login?" To "No" and now my upload speed is as expected !
Dec 10, 2021Guru - Experienced User
What happens if you configure the modem for router mode and configure the RBR for AP mode?
Have you powered OFF both modem and RBR for 1 minute then back ON?
- tgermainDec 10, 2021Aspirant
Hello,
turning off for 1 minutes didn't help, but switching to AP mode did (-> upload speed is as expected).
The end goal is to keep the router mode (there is much more options in the rbr20). So, do you know what could be the cause ?
Thanks for your help !
- FURRYe38Dec 10, 2021Guru - Experienced User
Possible problem between the modem and RBR.
What happens if you leave the modem in router mode. Configure the RBR for router mode and use the modems DMZ for the IP address the RBR gets from the modem?- tgermainDec 10, 2021Aspirant
So my modem is in router mode (so it gets a public IP), orbi also in router mode (so it gets a second public IP) right ?
I tried to put my second public ip (the one the orbi gets) in the DMZ of the modem, but it says the address is not in IPv4 pool range :smileyfrustrated: (and yes, the IP is correct. You know why I want to get the orbi in router mode ^^)
