tgermain
Dec 09, 2021Aspirant
Orbi RBR20 - no upload speed
Hello ! So my problem is about upload speed (download speed is as expected). I should have about ~20 mbps according to my ISP, but I only have something arround 0.01 (yes really !). I have a ...
- Dec 13, 2021
I found the solution.
On my internet setup page, I configured PPPOE with my login/passw coming from my ISP. I just change "Does your Internet connection require a login?" To "No" and now my upload speed is as expected !
Dec 10, 2021Guru - Experienced User
Possible problem between the modem and RBR.
What happens if you leave the modem in router mode. Configure the RBR for router mode and use the modems DMZ for the IP address the RBR gets from the modem?
tgermain
Dec 10, 2021Aspirant
So my modem is in router mode (so it gets a public IP), orbi also in router mode (so it gets a second public IP) right ?
I tried to put my second public ip (the one the orbi gets) in the DMZ of the modem, but it says the address is not in IPv4 pool range :smileyfrustrated: (and yes, the IP is correct. You know why I want to get the orbi in router mode ^^)
- FURRYe38Dec 10, 2021Guru - Experienced User
tgermain wrote:
So my modem is in router mode (so it gets a public IP), orbi also in router mode (so it gets a second public IP) right ? NO.
What IP address does the RBR get in router mode on it's WAN port? It should be a 192 or 10 kind of address. Input this IP address into the modems DMZ...
- tgermainDec 10, 2021Aspirant
Well, since the orbi is in router mode (and not AP mode) it gets a public IP on it's WAN port , it doesn't get any private ip from modem's DHCP.
You sure the modem is in router mode? When in router mode it should get a private IP address from the modems LAN side. Unless you have IP pass thru set if thats a feature on this modem.
