NetKnight
Jan 11, 2023Aspirant
Orbi RBR20 - Understanding brief sudden unavailability
With our Orbi RBR20 with 2 RBS20 satellites, I am sometimes experiencing sudden interruptions where the entire WiFi signals (and thus internet connection for all mobile devices) will be gone for a fe...
NetKnight
Thank you for your prompt responses plemans and Mikey94025, much appreciated.
Hardware version: RBR20
Firmware version: V2.7.3.22, on main device and the two sattelites
The RBR20 is connected via ethernet cable to a Sagemcom F@st 3890V3 WU cable modem, which was specially manufactured for TDC, a telco here in DK. The uplink is 1000 Mhz.
The loss of connection happens once per two/four weeks. I will start tracking in detail.
Yes, all devices loose access, since I do not see any Wifi signal anymore. When it happened today, I opened Wifi Explorer Lite on macOS and I did not see activity on any band or channel; all networks were gone. I did not have a device physically plugged in, but I will make preparations to test next time this happens.
The current system uptime shows 06:17:32, which is in line with a full restart / power interruption earlier today. We did not have a problem with the electricity at that moment.
KevinLiT
Jan 11, 2023NETGEAR Moderator
Hello Netknight,
Welcome to the NETGEAR Community!
I understand that you are having interim network issues with no additional changes to your network. Your post says that you are on version 2.7.3.22. Have you tried updating to the most recent firmware for your RBR20 FW v2.7.4.24?
Best,
Kevin
Community Team
