Ruskiwi
Jan 11, 2020Aspirant
Orbi RBR20 - upgrading Firmware from 2.3.5.26 to 2.3.5.36
Greetings. Received an email from Netgear recently that a new firmware version was available and to upgrade (V2.3.5.36). Logged in to Netgear Support and found 2.3.5.36 to download which I have done...
- Jan 11, 2020
You can manually update to v36 by downloading the RBS and RBR FW files from NG download site. Using a wired PC and Web browser, send the RBS FW file first, then update the RBR lastly.
Also if the system is working well, you don't have to update FW.
The Orbi App or Web page may not reflect new FW as it may not be posted to the Update servers as of yet.
Jan 11, 2020Guru - Experienced User
Ruskiwi
Many thanks for the prompt response and your knowledge. All things considered, your Option B seems the one I'll go for: "if it ain't broken, don't try to fix it" ! I'll wait until a mandatory FW upgrade notificatiion appears. Thanks again.
- FURRYe38Jan 12, 2020Guru - Experienced User
Enjoy.
