Marfog's avatar
Marfog
Follower
Nov 08, 2020
Orbi RBR20 + 2xRBS20 problem with devices
Hi,
All my devices Connect to the router wich is the RBR20. I have no devices in the list from any of my two satellites. I had it before but now it’s very strange. My PS4 device has very poor signal because it choose RBR20 instead of the nearest satellite. Why? All hardware is up to date. I have disabled daisy-chain.
But if I look in the admin portal it looks like PS4 is connected to one of my satellites, very strange. Can’t see that in mobile app. I willl upload some pictures aswell. Any suggestions?
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
