Jo1234
Aug 19, 2020Follower
Orbi rbr20 : Firmware Check Error and router blocking our info to the router.
We cannot use our Orbi RBR 20 on our wired computer. The WiFi is working and we have a strong signal From our internet provider. We are getting error messages -that our calendar is connecting to a s...
Aug 19, 2020Guru - Experienced User
What firmware are you on with the orbi? And the satellites?
What modem/gateway are you connecting to?
Did this issue just occur or has this been going on since you set it up?
Mstrbig
Aug 19, 2020Master
I doubt this has anything to do with the Orbi, unless you configured security.
What version of Safari are you using. It appears IOS13 has issues with Safari not establishing a secure connection on IOS13.
The 3 most popular methods for repairing this error on the Imac are:
- Open System Preferences and go to Network;
- Click Advanced;
- Navigate to the DNS tab and click + button;
- Enter 8.8.8.8 and hit Enter;
- Once again, click + button;
- Submit 8.8.4.4 and click Enter afterward;
- Hit Ok and Apply buttons.
- Open the site which shows Safari can't establish a secure connection error;
- Navigate to the address bar and click the (Lock icon) Secure button;
- Select More information;
- Click on View Certificate and check which certificate is in use;
- Go to Details tab and click Command + Space buttons at the same time;
- In the Spotlight Search enter Keychain;
- On the left panel select System Roots;
- Search for the website's certificate;
- Click on it and expand Trust section;
- On When using this certificate section select Always trust.
- Go to System Preferences;
- Open Network;
- Select Ethernet and click on Advanced button;
- Pick Manually on Configure IPv6;
- Hit Ok and click Apply.
