KB9JMH
Dec 13, 2019Follower
Orbi RBR20 5EH3855N022C
I have the RBR20 and one (included in box) satellite receiver. The systems works pretty well but I'm wondering if I can improve my signal strrength by adding one more satellite. The folks at a local ...
Dec 13, 2019Guru - Experienced User
Yes you can add more satellites. Other users have posted having up to 6 RBS connected to 1 RBR.
KB9JMH wrote:I have the RBR20 and one (included in box) satellite receiver. The systems works pretty well but I'm wondering if I can improve my signal strrength by adding one more satellite. The folks at a local store have givenm two DIFFERENT answers! (What a surprise!!)
One tech said no, this system is fixed the way it came in the box. The other of course said sure you can!
So, which is correct??
If I can add a satellite, which do you suggest??
Thahks so much
KB9JMH
