Rokais_72
Feb 16, 2021Aspirant
Orbi RBR20 and Satellites Repeatedly Losing connection to router
I have had my system just shy of a year and for the most part things were great until the firmware updates destabilized my connections in terms of the satellite connection to the router. I have been ...
vajim
Feb 17, 2021Master
Questions questions
just tell us yout firmware
- Rokais_72Feb 17, 2021Aspirant
Firmware version: 2.6.2.104
- vajimFeb 17, 2021Master
Rokais_72 wrote:Firmware version: 2.6.2.104
All I can offer is IF your problems started AFTER this firmware, then get rid of it and revert back.
OR....................you can sort through the other suggestions and be prepared to answer dozens of questions none of which may fix your problem. The choice is yours.
How do I revert to a previous firmware?
- CrimpOnFeb 17, 2021Guru - Experienced User
Desperate times call for desperate measures (Hippocrates). I can think of two:
- Do the dreaded "Factory Reset" on the Orbi router and satellites.
https://www.youtube.com/watch?v=cMw4ePACgc4
People hate doing this because the system has to be configured from scratch. (I usually save a copy of the config and try the option to "load a previous configuration" during the setup. If that fails, then I am stuck with over an hour of tedious typing.)
If this fails to stabilize the system, then... - Manually load an older firmware release on the router and satellites. 2.5.1.16 was very stable for a long time.
