Rokais_72
Feb 16, 2021Aspirant
Orbi RBR20 and Satellites Repeatedly Losing connection to router
I have had my system just shy of a year and for the most part things were great until the firmware updates destabilized my connections in terms of the satellite connection to the router. I have been ...
Feb 16, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Rokais_72
Feb 17, 2021Aspirant
What Firmware version is currently loaded? 2.6.2.104
Has a factory reset and setup from scratch been performed since last FW update? No
What is the size of your home? Sq Ft? ~ 2700 Sq Ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Router is in the basement, 1 on main floor, and 1 on top floor.
Any Wifi Neighbors near by? If so, how many? Auto channels, I have not tried manully changing for 2.4 Ghz and 5Ghz yet. Lots of WiFi neighbours in my townhome complex (5 - 8 nearby)
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings I did try enabling Beamforming and MIMO and there was no change.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Armor, Daisy Chain, Fast Roaming are all active, Circle and IPv6 are not enabled, I have not yet tried the 20/40Mhz change or Preamble from short to long.
One User Experience/Configuration: I will read these linked
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
