ThomasSayle
Nov 10, 2019Aspirant
Orbi RBR20 and SonicWall Mobile Connect
Hello all!
I am hoping that someone out there can help. I have a home office and have to use SonicWall Mobile Connect on my Macbook Pro to access some of my companies websites.
As configured, I can access all of these outside of my home when connected to the Internet. However, as soon as I come home, I am no longer able to access any of those protected sites. The websites just spin and then error out.
I am convinced that my Orbi router is blocking the connection, but I have no idea how to configure it properly. I am seriously considering just buying an additional router and simply connecting my Macbook to it in hopes that I can get it to work.
Anyone have any ideas on how to set this up to work properly?
I am using:
RBR20 from Orbi
MacBook Pro (running Mojave 10.14.6)
Any help is greatly appreciated.
Thanks,
T
- ekhalilMaster
I'm using few different VPN tunnels to access my company's and -sometimes- my customer's web sites, I have no issues with this with Orbi.
Your issue can be caused by multiple routers in your network. What is the type and model of the ISP modem/router to which Orbi is connected?
- ThomasSayleAspirant
The Orbi is connected to an Arris Surfboard SB6190. Spectrum Internet service.
- ekhalilMaster
Just to try to isolate the issue to Orbi, will you please be able to connect a computer directly to the cable modem and see if you see the the same issues.
- mikey72Aspirant
Hi - did you ever solev this problem? I have the same issue and would love some help.
- juekerAspirant
I updated the firmware on my RBR20 mesh system and then spent a day trying to get the system up and running again. I started to notice some sites were asking for modem login info. Then I discovered some of my service connections no longer worked. It wasn't until a few days later I decided to try a direct connect from my isp. Every thing started to work!!!
So I came to the Netger community to investigate if others were having simiiar issues and yes there are a number of posts with users having the same issue. Someone suugested using a VPN. I did this and all sites connect, however VPN slows the connection speed.
I then tried to contact Netgear directly, but alas they do not have direct support after 90 days. I am Canadian and I cannot even puchase their premium support. I cannot even find a way to call direct, the site revolves around to the same point.
Netgear, fix the issue and send out a firmware update.
jueker wrote:I updated the firmware on my RBR20 mesh system and then spent a day trying to get the system up and running again. I started to notice some sites were asking for modem login info. Then I discovered some of my service connections no longer worked. It wasn't until a few days later I decided to try a direct connect from my isp. Every thing started to work!!!
