ThomasSayle
Nov 10, 2019Aspirant
Orbi RBR20 and SonicWall Mobile Connect
Hello all! I am hoping that someone out there can help. I have a home office and have to use SonicWall Mobile Connect on my Macbook Pro to access some of my companies websites. As configure...
jueker
Feb 24, 2020Aspirant
My isp router is ARCADYAN (model VRV9519BWAC23)
Speed is 60Mbs down / 10Mbs up (and that is what speedtest.net displays)
Feb 24, 2020Guru - Experienced User
If your ISP modem has built in wifi and a router, then having the RBR online at the same time can cause problems. Seems that your model has WiFi and a router built in. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jueker wrote:My isp router is ARCADYAN (model VRV9519BWAC23)
