ptrondsen29
Aug 05, 2020Aspirant
Orbi RBR20 Backhaul Ethernet/Switch
Hello All, I'm having a problem with my Netgear Orbi. Here's the setup Netgear RBR20, with 2 satellites. I'm using the router with FIOS, and not using using a FIOS modem, direct ethernet from the O...
- Aug 05, 2020
CAT6 would be recommended and to use ALL cat6 cabling.
IF the connection works with out the switch then seem to have problems with the switch, then the switch would be a cause of the problem. I see this model switch has green ethernet features, (Energy Efficient Ethernet) 802.3az standard. Something that causes problems with Orbi Systems.
Aug 05, 2020Guru - Experienced User
Does the FIOS modem have a built in router? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What Firmware version is currently loaded on the Orbi?
What is the Mfr and model# of the ethernet switch in the configuration?
How the RBS should be connected to the RBR if a switch is used:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
ptrondsen29
FURRYe38 The FIOS Modem has been removed and returned to FIOS, I am going straight from the ONT to WAN port of the Orbi.Orbi has the latest firmware, V2.5.1.16
The Ethernet switch, is Linksys LGS105, non managed switch.
Thanks,
Pete
FURRYe38 wrote:Does the FIOS modem have a built in router? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
What is the Mfr and model# of the ethernet switch in the configuration?How the RBS should be connected to the RBR if a switch is used:
