ptrondsen29
Aug 05, 2020Aspirant
Orbi RBR20 Backhaul Ethernet/Switch
Hello All, I'm having a problem with my Netgear Orbi. Here's the setup Netgear RBR20, with 2 satellites. I'm using the router with FIOS, and not using using a FIOS modem, direct ethernet from the O...
- Aug 05, 2020
CAT6 would be recommended and to use ALL cat6 cabling.
IF the connection works with out the switch then seem to have problems with the switch, then the switch would be a cause of the problem. I see this model switch has green ethernet features, (Energy Efficient Ethernet) 802.3az standard. Something that causes problems with Orbi Systems.
Aug 05, 2020Guru - Experienced User
Can you remove the switch from the mix to see if the RBS will connect directly behind the RBR?
Be sure to disable Daisy Chain on the RBR before hand.
