ptrondsen29
Aug 05, 2020Aspirant
Orbi RBR20 Backhaul Ethernet/Switch
Hello All, I'm having a problem with my Netgear Orbi. Here's the setup Netgear RBR20, with 2 satellites. I'm using the router with FIOS, and not using using a FIOS modem, direct ethernet from the O...
- Aug 05, 2020
CAT6 would be recommended and to use ALL cat6 cabling.
IF the connection works with out the switch then seem to have problems with the switch, then the switch would be a cause of the problem. I see this model switch has green ethernet features, (Energy Efficient Ethernet) 802.3az standard. Something that causes problems with Orbi Systems.
Aug 05, 2020Guru - Experienced User
Can you remove the switch from the mix to see if the RBS will connect directly behind the RBR?
Be sure to disable Daisy Chain on the RBR before hand.
ptrondsen29
Yes, that's what I've done and the 50 foot Ethernet cable works fine with one computer.
Someone told me to get a cable that's backwards compatible with CAT5e. the one I have is CAT6.
FURRYe38 wrote:Can you remove the switch from the mix to see if the RBS will connect directly behind the RBR?
- FURRYe38Aug 05, 2020Guru - Experienced User
- ptrondsen29Aug 05, 2020Aspirant
FURRYe38 wrote:CAT6 would be recommended and to use ALL cat6 cabling.
Okay, I wasn't sure if it was a green switch, I have a couple other Linksys switches, which seem to have the same issue,
I'll try a netgear, non-green switch.
Thanks,
Pete
:smileywink:
