ptrondsen29's avatar
ptrondsen29
Orbi RBR20 Backhaul Ethernet/Switch
Hello All, I'm having a problem with my Netgear Orbi. Here's the setup Netgear RBR20, with 2 satellites. I'm using the router with FIOS, and not using using a FIOS modem, direct ethernet from the O...
  • FURRYe38's avatar
    CAT6 would be recommended and to use ALL cat6 cabling.
    IF the connection works with out the switch then seem to have problems with the switch, then the switch would be a cause of the problem. I see this model switch has green ethernet features, (Energy Efficient Ethernet) 802.3az standard. Something that causes problems with Orbi Systems.
