kev160967
Feb 09, 2021Aspirant
Orbi RBR20 Bandwidth control and AP/Router mode
Recently installed a 3 node RBR20 system and started migrating from my previous system, a Draytek router and access point. Generally been a good experience, but one aspect that is killing things is t...
CrimpOn
Feb 09, 2021Guru - Experienced User
Yes on both counts.
Yes, Netgear shows no signs of implementing any sort of bandwidth control on the residential Orbi product line.
Yes, if the Orbi is placed in access point (AP) mode, then all devices will get their IP addresses from the Draytek router and the Draytek can do whatever it is capable of doing. Will have no effect on the WiFi side.
kev160967
Feb 11, 2021Aspirant
Cheers, sounds like its worth switching then. I guess just switch over and reboot the Orbi (assuming it doesn't reboot automatically) and everything will just fall into place (fingers crossed :-) )
