DingoNZ
Aug 30, 2024Follower
Orbi RBR20 base router not blue
I have RBR20 router + 2 satellites. The indicater light on top is not glowing at all. I purchased router etc approximately 4&1/2 years ago. It is working but weak coverage. I have restarted and sync...
DingoNZ2
Aug 30, 2024Tutor
I have restarted and synched router and satellites. It is a mystery why the router is not showing blue.
CrimpOn
Aug 30, 2024Guru - Experienced User
The router on the original WiFi5 Orbi products never "turns blue". See page 9 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Aside from the light, does the system appear to be working?
