Nicolette730
Nov 08, 2022Initiate
Orbi rbr20 compatible satellites
I have an Orbi RBR20 router & 1 wall plug In satellite they work great but they seem to only cover 1/2 the house and I’m in need of another satellite but I can’t find anywhere what models of satellite...
Nicolette730
Nov 09, 2022Initiate
Thanks, I couldn’t find any of those at a reasonable price either I ended up buying an orbi router & 2 satellites for less money then one compatible satellite would have cost 😅
Nov 09, 2022Guru - Experienced User
You do tend to find the kits renewed for cheaper than an individual satellite. Then you can either sell the router and make some $ back or use it as a backup in case the primary fails. 🙂
Glad you hear you got one though!
