AshrafulHasan's avatar
Apr 24, 2020
Orbi RBR20 compatible Sattelite
Hi.
2 questions please.
Question 1:
I am already on an ORBI RBR20 Router with no Sattelites. I want to add a Sattelite. Which model do I need to buy that will be compatible with my RBR20?
Alternarively, in case the above doesn't work or buying a Sattelite is expensive, which ORBI Router can I buy which will allow me to use the existing RBR20 as a Sattelite?
Question 2:
When I search for a firmware update the router doesn't find any. But when I Google I see a newer firmware on the Netgear website. Why does this happen? Should I manually update the RBR20 firmware?
Thank you in advance for the help.
Regars
