SATCHIRATOR
Jul 22, 2020Aspirant
ORBI RBR20 CONNECTION ISSUES AFTER UPDATING TO V2.5.1.16
I just updated my Orbi RBR20 router to the latest firmware version V2.5.1.16 and i have a big connection issue which is the router keeps rebooting every 10 seconds, knowing that before this update my...
- Jul 22, 2020
I would make contact with NG support to see what options are available to you.
Good Luck.
SATCHIRATOR
thank you for the answer and help; i downgraded the vesion of the firmware but the router keeps rebooting over and over again every 10 seconds.
Jul 22, 2020Guru - Experienced User
Good Luck.
- SATCHIRATORJul 23, 2020Aspirant
IT SEEMS THAT THE PROBLEM CAME FROM THE SATTELITE, yesterday i've tried to turn on the router without the satellite and it worked fine but when i turn on the satellite there where the problems begins and the router keeps rebooting so i guess the issue is related to the connection between the satellite and the router.
- FURRYe38Jul 23, 2020Guru - Experienced User
So even a reset of the RBS and re-sync is causing this problem?
Possible faulty RBS.
Distance is 30 feet or more in between the RBS and RBR?
