AndyJapp
Feb 20, 2019Guide
Orbi RBR20 constantly offline
I bought an Orbi RBR20 system a couple of weeks ago. First it worked well but then I updated the firmware. Since then the satellites have disconnected around 2-3 times a week (distance less than 10 m...
AndyJapp
Feb 21, 2019Guide
Hi!
Obtained lease: less than 30 minutes ago.
I don’t think this has got anything to do with DNS settings. Tried 8.8.8.8. If anything, it made things slower.
ekhalil
Feb 21, 2019Master
AndyJapp wrote:
Hi!
If disconnecting/connecting the WAN cable resolves the issue then this is very likely a DHCP request issue.
I don't understand what you mean by "less than 30 minutes ago". Please take a snapshot of the Orbi status window abot the lease time.
Thank you.
- AndyJappFeb 21, 2019Guide
Less than 30 minutes ago means that the lease was obtained under 30 minutes ago. I don’t quite understand how this might help, but here you go.
- ekhalilFeb 21, 2019MasterCan you please add the snapshot as an attachment instead of as a picture otherwise I will not be able to see it until a moderator approves the picture. :)
