BenZen
Apr 06, 2020Aspirant
ORBI RBR20 covd lock up disaster. I've got this aweful piece of gear and no support $$ for help.
ORBI RBR 20 mesh network. Also have nighthawk R7000. Am on day 25 of isolation and the orbi network has been an absolute disaster to get going. Unfortuntately i cant get anyone in to sort it o...
Apr 06, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You might want to try option #3...if your using the R7000 has your main router.
ALso let us know the mfr and model# of the ISP modem as well...
BenZen wrote:ORBI RBR 20 mesh network. Also have nighthawk R7000.
Am on day 25 of isolation and the orbi network has been an absolute disaster to get going. Unfortuntately i cant get anyone in to sort it or buy anything to replace it right now as the whole country is in lockdown.
]I'm getting the 404 and 401 errors to the point it's really effecting productivity.
Also need to install some more sonos speakers (have some set up already).
If someone has expertise and can help get this sorted, am happy to pay for your time. I'm techy enough to follow instructions. but not to hold the details of how this **bleep** works. and have no ambition to become an expert.
great concept but not worth the aggravation in my opinion. if you can help please let me know.
BenZen
thanks - but your not talking english and I have not idea half of what youve asked.
I'm also not able to spend hours reading up on what a double nat is??
Hoping someone has experience and will help who actually knows what they are dong and isnt all guess work.
