imacattack
Oct 07, 2021Aspirant
Orbi RBR20 Devices Connecting To Wrong Satillites ?
I am having issues with devices not connecting to the proper Orbi Satillite most are connecting to the Router rather then connecting to the closest Satillite is there a way to move the device to ther...
Oct 07, 2021Guru - Experienced User
it's up to devices ti pick and choose where they connect too.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
