imacattack
Oct 07, 2021Aspirant
Orbi RBR20 Devices Connecting To Wrong Satillites ?
I am having issues with devices not connecting to the proper Orbi Satillite most are connecting to the Router rather then connecting to the closest Satillite is there a way to move the device to ther...
imacattack
None of those solutions work at all.
I have devices connecting to a satillite on the other side of the house and vice versa and some straight to the Orbi router.
Netgear needs to look into this so you can select a device and make it connect to the correct satelillite.
PS. there is no power option ????
CrimpOn
Oct 07, 2021Guru - Experienced User
Transmit Power is on the Orbi web interface (http://orbilogin.net), on the Advanced Tab, Advanced Settings, WiFi Settings.
