imacattack
Oct 07, 2021Aspirant
Orbi RBR20 Devices Connecting To Wrong Satillites ?
I am having issues with devices not connecting to the proper Orbi Satillite most are connecting to the Router rather then connecting to the closest Satillite is there a way to move the device to ther...
Oct 08, 2021Guru - Experienced User
I meantioned this in my responce...
imacattack wrote:
None of those solutions work at all.
I have devices connecting to a satillite on the other side of the house and vice versa and some straight to the Orbi router.
Netgear needs to look into this so you can select a device and make it connect to the correct satelillite.
PS. there is no power option ????
imacattack
Oct 08, 2021Aspirant
- imacattackOct 15, 2021Aspirant
On another note I can not access the Orbi via the web browser as it will only connect me to my X500 Gamer Router ??? can only use the App.
- FURRYe38Oct 15, 2021Guru - Experienced User
Are you using two routers on the same line?
