JimiW
Dec 31, 2020Aspirant
Orbi RBR20 DHCP list order or Import/Export for modifying
Hi, So I have a RBR20 system with 3 satellites and the DHCP reservation is driving me crazy. I split IP addresses into blocks IE a family of smart devices will start at a different "10" to others...
Dec 31, 2020Guru - Experienced User
Orbi systems doesn't support the export of that kind of configuration.
You might see if there is a method to maybe modify a .conf file under telnet.
- JimiWDec 31, 2020Aspirant
ok, thanks. I haven't used Telnet for years so no idea. Is there no way to at least refresh and sort the list to show it in IP ascending order? That is all I really need at the end of the day.
FURRYe38 wrote:Orbi systems doesn't support the export of that kind of configuration.
- FURRYe38Dec 31, 2020Guru - Experienced User
You can take a look at this:
https://community.netgear.com/t5/Orbi/Orbi-SOAP-and-Excel/m-p/1898560
ok, thanks, will look into that.
