Bmeston's avatar
Bmeston
Follower
Sep 03, 2019
Orbi RBR20 dhcp settings
I just set up my new Orbi. Is it possible to change the DHCP server settings to use a different subnet than the default (192.168.x.x)?
  • i need help i turned off my wifi on the modem and now i cannot login to my modem.  i had hook up a mesh wifi and a coworker told me to turn off wifi.  i cannot get my wifi to work in bedroom or front room.
    kathy
  • FURRYe38's avatar
    Yes you can use 10.#.#.#.# or 172.#.#.#.#
