shaheernoor
May 29, 2020Guide
Orbi RBR20 disconnecting when Xbox One connects to an online game
I have one Orbi RBR20 Router and a Satellite placed throughout my home and both work great with speeds and range up to par. However once a day, when my Xbox One is on an online game, then the WiFi co...
- May 30, 2020try putting the xbox in the dmz
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
May 29, 2020Guru - Experienced User
I believe the current firmware version is 2.5.1.16.
Try upgrading the firmare.
What modem are you using?
- shaheernoorMay 29, 2020Guide
I've been using the modem with a previous WiFi router as well and did not have this issue with it. I am using a Hitron E31N2V1 modem
I checked for updates on my router (RBR20) via the Orbi app and it says there are no new updates.
- plemansMay 29, 2020Guru - Experienced User
The app isn't always correct. You can manually download and install the firmware.
- shaheernoorMay 30, 2020Guide
Ok, I have now updated my router (RBR20) to the latest firmware. I will let you know if the problem continues.
Thank you
