shaheernoor
May 29, 2020Guide
Orbi RBR20 disconnecting when Xbox One connects to an online game
I have one Orbi RBR20 Router and a Satellite placed throughout my home and both work great with speeds and range up to par. However once a day, when my Xbox One is on an online game, then the WiFi co...
- May 30, 2020try putting the xbox in the dmz
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
shaheernoor
May 30, 2020Guide
Aaaaand less than 12 hours later the problem remains. Before, the wifi would cut when the game round would be finished, but now it cut off right when the xbox joined the multiplayer server.
It seems that the firmware is not the problem. What else could it be?
May 30, 2020Guru - Experienced User
- shaheernoorMay 31, 2020Guide
Alright, I have put the Xbox on its own DMZ server, so far it has not shut the router down, we'll see what happens in the next few days
- FURRYe38Jun 01, 2020Guru - Experienced User
Try a factory reset of the RBR and setup from scratch.
Turn ON the xbox and set a IP address reservation on the RBR for the xbox. Save and apply and reboot the RBR.
Press and hold the power button on the front of the xbox until it shuts off. Wait for the RBR to reboot.
I recommend not using the DMZ for the xbox. It shouldn't be needed.
shaheernoor wrote:Alright, I have put the Xbox on its own DMZ server, so far it has not shut the router down, we'll see what happens in the next few days
- shaheernoorJun 23, 2020Guide
Do i need to keep the DMZ server webpage open for it to work? If not, then I am still experiencing the same issue as before. I do not understand why this is, it is a new router which comfortably fits the number of devices we run, yet it still runs into problems when the Xbox switches from various multiplayer lobbies.
If there is any fix please let me know.
- FURRYe38Jun 23, 2020Guru - Experienced User
DMZ should be disabled.
Did you configure and run thru the last suggestion?
Does the problem happen if the xbox is wire connected to the RBR?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
