shaheernoor
May 29, 2020Guide
Orbi RBR20 disconnecting when Xbox One connects to an online game
I have one Orbi RBR20 Router and a Satellite placed throughout my home and both work great with speeds and range up to par. However once a day, when my Xbox One is on an online game, then the WiFi co...
- May 30, 2020try putting the xbox in the dmz
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
May 30, 2020Guru - Experienced User
shaheernoor
May 31, 2020Guide
Alright, I have put the Xbox on its own DMZ server, so far it has not shut the router down, we'll see what happens in the next few days
- FURRYe38Jun 01, 2020Guru - Experienced User
Try a factory reset of the RBR and setup from scratch.
Turn ON the xbox and set a IP address reservation on the RBR for the xbox. Save and apply and reboot the RBR.
Press and hold the power button on the front of the xbox until it shuts off. Wait for the RBR to reboot.
I recommend not using the DMZ for the xbox. It shouldn't be needed.
shaheernoor wrote:Alright, I have put the Xbox on its own DMZ server, so far it has not shut the router down, we'll see what happens in the next few days
