casadlocho
Jul 21, 2020Aspirant
Orbi RBR20 does not have wifi internet while connected to a switch
After so many factory resets i finally figured out why i keep losing my wifi internet. My home network looks like this: COX > MODEM (CM1100) Port 1 > ORBI RBR20 INTERNET PORT > ORBI ETHERNET ...
casadlocho
As soon as i remove the connection to the switch and connect all device to wifi alone then it starts working again.
Jul 21, 2020Guru - Experienced User
People have reports issues with some green switches or managed switches.
What switch do you have?
- casadlochoJul 21, 2020Aspirant
I have the netgear prosafe GS108.
My goal is that all house hold mobile devices to be connected through wifi.
And for my desktop and laptop to be wired via switch.
- FURRYe38Jul 21, 2020Guru - Experienced User
Faulty switch or cabling? Try a different switch. CAT6 LAN cable is recommended.
Switch and Cables are all a week old.
Cables are CAT 6.
