RFRCEK961
Jun 14, 2020Aspirant
Orbi RBR20 Doesn't Connect to Internet for WiFi for New Spectrum Modem
Spectrum said they are upgrading their equipment and sent a new HITRON E31N2V1 Modem. I connected the modem to the Orbi RBR20 and ran the ethernet from the Orbi to my desktop computer. I have 3 satell...
- Jun 15, 2020
RFRCEK961 wrote:
Spectrum said they are upgrading their equipment and sent a new HITRON E31N2V1 Modem. I connected the modem to the Orbi RBR20 and ran the ethernet from the Orbi to my desktop computer.Did you just swap out one modem for another with the Orbi RBR20 router in place?
If so, you may need to persuade the Orbi to forget any bad habits it picked up from the old modem. When you first set it up, it will have looked for things like the Mac address of your old modem. But that information is no longer relevant.
Disconnect the Orbi, do a factory reset on it, and then go through the same setup process that you did when you first installed the RBR20.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
michaelkenward
Jun 15, 2020Guru - Experienced User
Support | NETGEAR
RFRCEK961
Jun 15, 2020Aspirant
Thanks. That worked. After wasting 2 hours on the phone with Spectrum and then purchasing a useless Netgear support contract and spending 2.5 hours on the phone with 3 reps and getting nothing accomplished, I saw your post, tried it, and all is well. Thank You.
