Ashraful
Jan 29, 2020Tutor
Orbi RBR20 DoS attacks disrupting internet connectivity
Hello. Recently I started losing the internet connection from time to time. Upon checking of my router log I noticed that there are repeated DoS attacks in the forms of ACK Scan, SYN/ACK Scan, RT...
- Feb 08, 2020
Hi. This was eventually reswolved by the ISP changing my IP. No one could conclusively tell me what actually had gone wrong.
Jan 29, 2020Guru - Experienced User
What happens if you power OFF the RBR and ISP modem for 5 minutes, then back ON?
You might have your ISP help you change the WAN IP address on the modem to something else...
use whois.domaintools.com to look up where those IP addresses are coming from.
- AshrafulJan 29, 2020Tutor
Hi and thanks for the quick response.
The manufacturer of the Mfr seems something local but the model number written is FD600-504G-HR220.
When i power off the modem and the router there is another issue - the modem is back up in 1 min but the router says there is no internet. This deters me from turning off the devices as it takes 3/4 attempts to have the router working. the router and Mfr is connected by wire.
My ISP told me that changing the WAN would only be a temporary solution. They are suggesting for a factory reset of the Orbi.
- AshrafulJan 29, 2020TutorSorry missed one response. I have looked up the ip addresses and it seems to be from Russia, France, USA, Germany and the list goes on. The only common thing from all the attacks of today seems to be the port 443?
