Ashraful
Jan 29, 2020Tutor
Orbi RBR20 DoS attacks disrupting internet connectivity
Hello. Recently I started losing the internet connection from time to time. Upon checking of my router log I noticed that there are repeated DoS attacks in the forms of ACK Scan, SYN/ACK Scan, RT...
- Feb 08, 2020
Hi. This was eventually reswolved by the ISP changing my IP. No one could conclusively tell me what actually had gone wrong.
Jan 29, 2020Guru - Experienced User
What happens if you power OFF the RBR and ISP modem for 5 minutes, then back ON?
You might have your ISP help you change the WAN IP address on the modem to something else...
use whois.domaintools.com to look up where those IP addresses are coming from.
Ashraful
Jan 29, 2020Tutor
Sorry missed one response. I have looked up the ip addresses and it seems to be from Russia, France, USA, Germany and the list goes on. The only common thing from all the attacks of today seems to be the port 443?
