Ashraful
Jan 29, 2020Tutor
Orbi RBR20 DoS attacks disrupting internet connectivity
Hello. Recently I started losing the internet connection from time to time. Upon checking of my router log I noticed that there are repeated DoS attacks in the forms of ACK Scan, SYN/ACK Scan, RT...
- Feb 08, 2020
Hi. This was eventually reswolved by the ISP changing my IP. No one could conclusively tell me what actually had gone wrong.
Ashraful
Jan 29, 2020Tutor
Hi and thanks for the quick response.
The manufacturer of the Mfr seems something local but the model number written is FD600-504G-HR220.
When i power off the modem and the router there is another issue - the modem is back up in 1 min but the router says there is no internet. This deters me from turning off the devices as it takes 3/4 attempts to have the router working. the router and Mfr is connected by wire.
My ISP told me that changing the WAN would only be a temporary solution. They are suggesting for a factory reset of the Orbi.
Jan 29, 2020Guru - Experienced User
Can try a reset though I doubt this will help.
- AshrafulJan 29, 2020Tutor
No other suggestions? What would be causing these disruptions?
- FURRYe38Jan 30, 2020Guru - Experienced User
See if your ISP can change the WAN IP address on the ONT. All this is coming in from the WAN side.
- AshrafulFeb 02, 2020TutorHi. The ISP has converted me to a public IP from a real IP. Unfortunately the DoS attacks continue. Neither my ISP nor I Know what to do next. Can anyone kindly help?
