Gfiorita
Nov 23, 2018Tutor
Orbi RBR20 download speed half of upload
I have a 1 gbps up/down connection vis century link and my orbi is setup in AP mode behind the century link modem. I get 1 gb up and down via the wired connection from my orbi to a Mac Pro desktop....
Nov 24, 2018Guru - Experienced User
Wireless speeds will max out at around 500Mb depending upon client HW support and design. IF your getting wired speeds to spec, then the Orbi is working well. Always test wired speeds first.
