Sharenh3612
Feb 05, 2021Aspirant
ORBI RBR20 Drop signal every 10 minutes
ORBI2 I got my unit for less than 2 years. These few days, it started dropping signals in 10 minutes after it is reconnected. I called Tech support try to see if there is a hardware problem or soft...
nmpham
Mar 26, 2021Initiate
I experienced the same issue of the device dropping internet connection if there is no activity for a period of time. This issue started after almost 1.5 years of use of this device. Alrealdy verified that it has the most current firmware.
olympos1625
Apr 01, 2021NETGEAR Employee Retired
Hi nmpham,
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. When did the issue start? Does it affect all your wireless devices only or even the wired devices? Have you tried turning off the satellite and see if that drops the internet connection still? Have you tried contacting our Support team?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
