atholgraham
Aug 18, 2020Aspirant
ORBI RBR20 dropping internet
I have been having a lot of trouble wth my Orbi dropping the internet connectiion. The wifi signal is fine. I have change the wireless settings and reduced the transmission power, talked to teh ...
- Aug 27, 2020
I reset the ORBI and it seems to be working better. I have mnot touched any settings and left teh advanced Wireless settings as shown below
Mstrbig
Aug 18, 2020Master
When you say dropping internet, have you isolated it to the Orbi, or could it be problems with the ISP modem/router. I would check to see if you are getting rock solid internet through the ISP modem/router, check the network cable connecting your Orbi router to the ISP modem. Then if the problem still exists, I would reboot the system, check your settings, and if all else fails, reset the system and re-install.
- atholgrahamAug 27, 2020Aspirant
