Chillihilli
Mar 25, 2020Tutor
Orbi RBR20 Ethernet IP assignment
I fired up the Obi kit with 2 Satellites
I'm in Australia with a TPG HFC connection to the NBN. Enabled VLAN ID = 2 and everything connected via wifi. (Great setup BTW)
Nothing, and I mean NOTHING, will connect via the wired ethernet port
I plug the Samsung TV in direct to the RBR20 router. No joy.
I plug a netgear unmanaged switch to the router, then connect a TV through that. No joy.
I plug my Mac laptop via USB ethernet to the router, nothing.
It seems to not assign IP addresses over wired connections.
So I pulled the plug on the NBN modem. Left it off for a couple of hours and sequentially fired everything up starting with the NBN modem. I thought it might be an IP assignment issue from the NBN modem, but it still doesnt work.
Can anyone help with this?
Modem -> RBR20 -->RBS20 (x2) all working fine.
What is the purpose of VLAN ID=2?
What I read about VLAN's in the Orbi User Manual seems to indicate that VLAN is needed for IPTV, but not for "regular devices".
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf Starting on page 84
VLANID=2 is required by our internet provider (TPG). Can't connect without it
https://community.netgear.com/t5/Orbi/VLAN-tagging-for-TPG-NBN/m-p/1657541#M44246
CrimpOn wrote:What is the purpose of VLAN ID=2?
Did I read correctly that devices connected to Orbi via WiFi are working correctly, and only devices connected via ethernet are not?
Can you try to restrict the VLAN to only a single Orbi port (uncheck the other two ports) and see if an ethernet device will work on one of them?
