MisakiShinimiya
Mar 26, 2023Follower
ORBI RBR20 firmware update trouble
Since Orbi app cannot update my RBR20 to 2.7.2.4.24 version, therefore I choose to update manually. manual said that we should update firmware on satellites first and then update router, however I pr...
- Mar 26, 2023
You need to use the RBS version of the FW to send to the RBS. You can't use the RBR version.
Mar 26, 2023Guru - Experienced User
