MisakiShinimiya
Mar 26, 2023Follower
ORBI RBR20 firmware update trouble
Since Orbi app cannot update my RBR20 to 2.7.2.4.24 version, therefore I choose to update manually. manual said that we should update firmware on satellites first and then update router, however I pr...
- Mar 26, 2023
You need to use the RBS version of the FW to send to the RBS. You can't use the RBR version.
KevinLiT
Mar 28, 2023NETGEAR Moderator
Hello MisakiShinimiya,
Welcome to the NETGEAR Community!
I understand that you would like to update your RBK20 Orbi Mesh System to the current FW 2.7.4.24. The Orbi satellite and the router does not use the same FW update file. To identify the files please take note of the downloaded zip folder names. The file for the router starts with RBR while the satellite's download file starts with RBS.
Please navigate to the link below for the correct download file for your RBS20 FW v2.7.4.24:
Orbi RBK23 | WiFi System | NETGEAR Support
For more information on manually updating your RBK20 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
Community Team
