jcotillo
Aug 26, 2020Aspirant
Orbi RBR20 Firware: V2.5.1.16 Wifi speed slower than received
Hello community, I have an Orbi RBR20 and two satellites: RBS20 -> Firmare: 2.5.1.16 and RBW30 -> Firmware 2.5.0.4 Have a 600MB cable internet plan. When I test the speed from the modem to th...
CrimpOn
Aug 26, 2020Guru - Experienced User
jcotillo wrote:Have a 600MB cable internet plan. When I test the speed from the modem to the router RBR20, the speed is 600MB and sometimes a little bit more, but if I connect to the wifi of the same router, the speed doesn't get more than 350MB, other satellites get to 250MB tops.
Although the RBR20 claims a link rate of 866mbs on the 5G band, that does not mean that a WiFi device will actually achieve that much.
This article from 2015 goes into some depth describing "what is likely" with different WiFi connections:
https://www.speedguide.net/faq/what-is-the-actual-real-life-speed-of-wireless-374
Notice the statement: "In addition, net IP layer throughput of WiFi is typically 60% of the air link rate due to WiFi being half-duplex with ACKs, and being CSMA/CA. The number of simultaneous connections, and even the type of wireless security can affect and slow down some older routers with inadequate processors/memory."
What is the reported "link rate"? (The Orbi "app" reports the link rate for each device.)
What is 60% of that?
jcotillo
Nope, link rate says 866 Mbps, at least that's what is says related to the laptop I am testing the speed with.
